HELP! Unidentifed part in rear hub.
If your having problems with your bicycle, or just need help fixing a flat, drop in here....
Postby SexJihaad9/11 » April 5th, 2012, 8:50 am
After hearing a rattle in my road bike's rear hub for a few days I finally took it to the LBS and the guy pulled this part out and sent me on my way.
The bike seems fine and the rattle is gone but I'm sure this part isn't just something the manufacturer put in for laughs. Also I don't really trust the guy but there aren't a lot of good bike shops where I live.
Anyone who knows what this part is, please let me know and tell me what I ought to do now.
SexJihaad9/11
My Goal: To not die or be horribly maimed while cycling.
Re: HELP! Unidentifed part in rear hub.
Postby Anool » April 5th, 2012, 9:23 am
Did he pull it out from INSIDE of the hub ?
to me, it looks like one of two possibilities :
this is the kind of bolt used to fix the chainrings to the crank
or, such bolts are used to fix the caliper brakes to the frame.
But, I cannot fathom what it would be doing inside a hub.
Cheers,
Anool J M
Mumbai, IN
2012 Windsor TimeLine Single Speed Commuter |
2010 Ridley Crosswind CX
2008 Bianchi Spillo Quarzo | 2010~2011 - Sold
2006 Firefox Viper | 2007~2011 - Sold
Anool
My Goal: Keep Commuting, and try to keep fit.
Postby SexJihaad9/11 » April 5th, 2012, 9:30 am
Anool wrote:Did he pull it out from INSIDE of the hub ?
It was inside the hub. So, you're saying the manufacturers did put it in for laughs?
SexJihaad9/11
Postby Anool » April 5th, 2012, 9:33 am
Cheers,
Anool J M
Mumbai, IN
Anool
Postby dandekarvaibhav » April 5th, 2012, 9:45 am
Anool you rock! I was gonna post the same exploded view.
Wierd looking part huh!
Looks like an end cap to "something" while allowing "something" project out. :mrgreen:
I may sound demanding but believe me... only curious... can you help us visualize how it was inside the hub.... Not getting any sense of scale too.
No one gives it to you. You have to take it.
dandekarvaibhav
Postby Anool » April 5th, 2012, 9:56 am
dandekarvaibhav wrote:....I may sound demanding but believe me... only curious... can you help us visualize how it was inside the hub.... Not getting any sense of scale too.
yeah, me too. This case is so curious, it's begging to be solved.
Cheers,
Anool J M
Mumbai, IN
Anool
Postby SexJihaad9/11 » April 5th, 2012, 10:03 am
Here you go.
It went along the axis of the hub, with the QR skewer through it. Where exactly it was, I can't tell. That's what I'd like to find out actually.
Go nuts, gentlemen.
SexJihaad9/11
Postby psynide » April 5th, 2012, 10:35 am
just wondering, maybe this was used as a spacer? in any case, it doesn't look like a proper spacer ! probably the person assembling the hub ran out of it and pulled this thingamajig lying on the floor !
just like anool has said, it looks like a chainring bolt. weird !
two wheeled engineless fun machine
bsa slr
hercules mtb
streetcat rock n roll
hercules ez-y
hero thunder
firefox viper
ROCKYMOUNTAIN RM7 FR
FIREEYE SHORTFUSE 380
PSYNYDE CAFFEINE
psynide
My Goal: Almost there !
Postby prabuddhadg » April 5th, 2012, 11:01 am
Not trying to help here, but I have heard of Detroit cars from the 70's with rattling noises inside a door. With the lining removed, it revealed a beer can - probably left inside by a worker assembling the car.
Postby SexJihaad9/11 » April 5th, 2012, 11:04 am
Most of what Jeremy Clarkson says is purely for effect and not true at all. Sorry to break it to you.
SexJihaad9/11
Postby prabuddhadg » April 5th, 2012, 12:03 pm
Oh No! I am crestfallen!!
Postby SexJihaad9/11 » April 6th, 2012, 11:43 pm
Anyone? :(
SexJihaad9/11
Postby cryptic_abbreviator » April 6th, 2012, 11:48 pm
looks like one of those things from a V brake
off to check diagrams and see if that notion is right
I distinctly remember something like this from when the brakes on the wife's Q5 were not working (would not spring back) and i had taken the brakes apart.
ciao
gr
cryptic_abbreviator
Postby bblost » April 7th, 2012, 12:08 am
Is this called a Hub Cone.
http://www.ihpva.org/projects/tstrike/hub.jpg
http://sheldonbrown.com/cone-adjustment.html
I have seen a similar looking part in my motorcycles rear tire.
This is the last part in the tire. After this is a small cylinder about an inch long. Then the frame. After this the axle bolts head.
I always assumed this part was there to provide a smooth even surface. So that that cylinder gave balanced pressure to the wheel.
Motorcycle: 03 Thunderbird.
I don't mind coming to work, but this 6-hour wait to get back on the bike is irritating.
bblost
My Goal: Eat out more often and not exercise.
Postby SexJihaad9/11 » April 7th, 2012, 4:42 am
Thanks. Seems like it isn't non-essential then. I'm going to take it to a better bike shop and see if they can put it back in.
SexJihaad9/11
Next
Return to Bicycle troubleshooting
Users browsing this forum: No registered users and 0 guests
