Vandit can you clarify what you mean by the via agra stem?
This is similar to what I have right now (this is short and steep - a longer stem with the same angle puts the handlebars higher, but also too far away):
This is the stem raiser that I was talking about:
I was unsure about using the latter as a permanent solution because of concerns over it getting loose etc. Besides which it would look ugly as hell. I am more and more inclined to go for the new uncut fork with a flat stem, and then adjust that up and down (and play with stem length) as needed.
And if I do go the bike shop route, they will happily swap out the stem as needed going forward, and help with the adjustments etc. It helps that I have a Groupon for that bike shop that I need to use - so that eases the pain of shelling out the $$. And they will give me (some) credit for the old fork too.
You do not have the required permissions to view the files attached to this post.
